TwinTurbo.NET: Nissan 300ZX forum - HELP!! No clutch pressure and disegagement
Subject HELP!! No clutch pressure and disegagement
Posted by 2inTurbo on April 11, 2010 at 11:37 AM
  This message has been viewed 136 times.
Message My clutch will not disengage and the clutch pedal feels loose or soft,
another thing is that the trans won't go in gear whenever the engine is
running(it's fine with the enige off so I know it's not a trans problem) it's
like I'm not pressing the clutch. And whenever I try to start the engine in
gear it stalls out right away.
Ok here is what led to this: I replaced the clutch and the flywheel.
I felt the pedal after and it was nice and stiff but then I bled it and it
went completely soft with no pressure, I bled it just like you bleed brakes
pedal down-open valve, close valve-pedal up. I'm thinking maybe I blew
the seals in the master or I bled it wrong so that I trapped a lot of air in
the system. I'm hoping it's that and nothing mechanical.
Thanks for any help
